Skillings
Apr 27, 2021Follower
can I add a 2nd satellite to my existing SRR60
I bought an SRR60 Orbi Mess network I would like to add a second sateliite onto the orginal system I have the Orbi Pro Router SRR60 with one satelitte? Which model should I order?
Thank you
Don
The SRS60 is the satellite.
The SRR60 is the router.
So you'd want the SRS60
The SRC60 — Orbi Pro AC3000 WiFi 5 Tri-band Add-on Ceiling Satellite is also workable with the Orbi Pro system - and typically better suited to work for ceiling or wall mount.
