mmordaunt
Dec 12, 2017Follower
Cannot set security on WAC104 Wireless access point
Hi There, Have the wireless access point hard wired by Cat5E to the main home router (which has WEP/WPA security active) and following the online manual it says to go open a web browser on a wir...
- Dec 19, 2017
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Dec 19, 2017NETGEAR Employee Retired
