cosmolee
Apr 01, 2021Aspirant
Configure wireless access points to block websites per SSID??
Hi, is there any way to block websites, URL keywords, etc per a given SSID? Eg: In our business, we would like to create an SSID that allows full access to the internet, but another SSID that wou...
cosmolee
Apr 09, 2021Aspirant
I received an email with a link that says: "Check it out! Your topic recently received a reply!"
The link is broken and goes nowhere. The URL is literally: "http://link/" I had to manually login to find a reply from a week ago.
Netgear fobbing off support to the "Netgear Community", and the poor execution of it, is a reason I won't be buying Netgear equipment in the future.
schumaku
Apr 09, 2021Guru - Experienced User
I'm just an (active) normal and non-privileged user here, so receiving virtually dozens of such emails, the URL format is like this (these are real ones taken from the notification I've received)...
Re: Configure wireless access points to block websites per SSID??
...and does perfectly point to the very exact reply. Community sections which are open show the reply. Restricted sections require a login, and so is if you intend to reply.
Check your undefined email service, email client, look for some Internet Security junk having his fingers in your data path. Almost convinced this isn't a community SaaS (very popular with many other brands for the similar purpose!) or a Netgear problem.
