scotty134's avatar
scotty134
Connection WAC730
Hi to everybody!   I would like to buy couple staff but I want to make sure that I no need anything else. I want to buy 2 WAC730 and ProSafe Smart Managed Switch XS716T-100NES or Web Managed Switc...
  • DaneA's avatar
    Apr 09, 2017
    Hi scotty134,
    You may use the WAC730 with either the XS716T switch or the XS716E switch.  If I were to choose, I would prefer the XS716T.  One reason is because the XS716E only supports static LAG while the XS716T supports static LAG and LACP.
    For me, a wireless controller is not appropriate since you will use only 2 WAC730 access points.  I suggest you to configure an Ensemble Mode Management.  To know about Ensemble Mode Management, kindly access the article below:
    WAC730 FAQs
    DaneA
    NETGEAR Community Team
ProSupport for Business
