ortizalfredt
Apr 06, 2026Aspirant
Custom Naming of Devices in the WAX610
Using the WAX610 AP web browser admin, under Management=>Monitoring=>Connected Clients, is there anyway to apply a "vanity" name to each device? Keeping track of MACs that jump in and out becomes te...
Apr 08, 2026Guru - Experienced User
I'm trying to remember if that is possible as I also have a WAX unit. I guess maybe time to reconnect it and find out.
I wanna say you could in the Insight mobile app, but it's been too long I think. I would think there should be a way...
Have you tried selecting one device and seeing there is any settings for it in the WEB UI?
- ortizalfredtApr 14, 2026Aspirant
I'm still learning about the WEB UI of the WAX610. Been playing around with it.
I'm also on page 239 of the 326 page user manual and nothing so far discusses naming.
In the "Connected Clients" list under Monitoring, Host Names are listed but i see no way to edit anything shown.
- FURRYe38Apr 14, 2026Guru - Experienced User
Thanks for checking.
Wondering if there is any way to change when using the Insight app.
- schumakuApr 15, 2026Guru - Experienced User
In the "Connected Clients" list under Monitoring, Host Names are listed but i see no way to edit anything shown.Correct: There is none - at least none on that end of the food chain. And none in Insight App nor in Insight Web portal.
The only option you have on certain devices is to provide a device name or host name, most (but not all) might forward that name accordingly.
Typical IoT don't allow device naming however.
A much smarter start would be on the router end, or more specifically on the DHCP side if things.
Some routers allow defining host names. Good DHCP servers are supplying the host name in the answer to the DHCP request in the device name field, which is provided to the DHCP client in the so called Option 12, aka, SYSNAME field. Keep in mind the field is limited to 30 ASCII characters, no spaces, ... so it represents a correct hostname.
On some devices, like the in any aspects capable HP printers, you might have to change the priority from Standard to DHCP inthe HP embedded Web server (EWS), so this field is accepted (instead of the standard NPIxxyyzz name, derived from the Network Printer Interface and the MAC address) is used.
Needless to say, this requires operating all the devices on the network in DHCP client mode.
As I said before: If there is no meaningful name specified, or an empty null byte string is provided, the code on these wireless APs does create one, based on the MAC address (along with the by far not perfect detection of the device manufacturer and the OS).
Conclude, there are much better places to define a hostname, than manually force one in place on an access point.
- Nov 30, 2019Retired_Member
