ortizalfredt
Apr 06, 2026Aspirant
Custom Naming of Devices in the WAX610
Using the WAX610 AP web browser admin, under Management=>Monitoring=>Connected Clients, is there anyway to apply a "vanity" name to each device? Keeping track of MACs that jump in and out becomes te...
ortizalfredt
Apr 08, 2026Aspirant
Hi schumaku, I get your valid point. I'm using the RBR20 in simple AP mode connected to a Netgate pfSense router. pfSense handles the DHCP. Nevertheless, the RBR20 in AP mode still allows me to go in an add vanity names to the mac's that appear on it's wifi. And as these devices come and go, their names seem to be remembered. I also have the WAX610 connected to a separate input port on the NetGate. I don't know how the WAX610 is designed but from what you say, i guess the WAX is somewhat dumb and doesn't have the ability to remember prior attendees and therefore has no place to store vanity names.
By the way, what's a "User Name", i.e. found on the Connected Clients list at the end of each device. All are set to "Unknown Username".
schumaku
Apr 08, 2026Guru - Experienced User
ortizalfredt wrote:RBR20 in simple AP mode connected to a Netgate pfSense router
What you see on the RBR20 - also in access point mode is also a leftover from it's DHCP server. Like many DHCP server, it allows to override the hostname coming slong as part of the DHCP request.
Similar, the Netgear devices - here the WAC WAX or WBE have some code on board trying to identify the device or the device OS connected. If this does not succeed, some hostname is defined based on the MAC address.
Like 12-5D-72-xx-xx-xx at home of the vZug connected kitchen devices for example.
On Netgear Insight, these show like
Client Name
12-5D-72-xx-xx-xx
MAC Address
12:5d:72:xx:xx:xx
IP Address
(RFC1918 IP here)
OS
Unknown Device OS
Associated AP
WBE758-nnn
Association Granted
Apr 08, 2026, 16:59 p.m. (CET)
Signal Strength
i
RSSI -68
BSSID
54:07:7d:nn:nn:nn
SSID
....Real SSID here..
Mode
11ax
MLO Supported
No
Radio
5 GHz
Channel
100
VLAN ID
nn
Said that: Even on Netgear Insight with the virtually unlimited cloud storage, these names can't be customized.
