RPL86812
Dec 10, 2018Aspirant
Default password does NOT work after firmware upgrade
I'm preparing to deploy (6) WAC510 AP units. I'm testing one unit standalone before deploying the other 5. I upgraded the firmware to 5.x latest and went through the day zero setup. After saving and ...
- Dec 12, 2018
Hi RPL86812,
Welcome to our community! :)
I suggest you to reset it to factory default and try to login again using the default password. Is this connected to a wireless controller before?
RPL86812
As a follow-up, I did change the default password. I'm trying that one too and it's still no joy. What am I missing?
- JohnC_VDec 12, 2018NETGEAR Employee Retired
Hi RPL86812,
- RPL86812Dec 12, 2018Aspirant
Thanks for your reply. It was not connected to anything before I updated the firmware and changed the password. I'll do a hard reset and use the default password. When I do the day zero setup, am I changing the admin password?
- RPL86812Dec 13, 2018Aspirant
OK, I reset the AP and the admin password and everything is working as it should.
