RPL86812
Dec 10, 2018Aspirant
Default password does NOT work after firmware upgrade
I'm preparing to deploy (6) WAC510 AP units. I'm testing one unit standalone before deploying the other 5. I upgraded the firmware to 5.x latest and went through the day zero setup. After saving and ...
- Dec 12, 2018
Hi RPL86812,
Welcome to our community! :)
I suggest you to reset it to factory default and try to login again using the default password. Is this connected to a wireless controller before?
RPL86812
As a follow-up, I did change the default password. I'm trying that one too and it's still no joy. What am I missing?
JohnC_V
Dec 12, 2018NETGEAR Employee Retired
Hi RPL86812,
- RPL86812Dec 12, 2018Aspirant
Thanks for your reply. It was not connected to anything before I updated the firmware and changed the password. I'll do a hard reset and use the default password. When I do the day zero setup, am I changing the admin password?
- RPL86812Dec 13, 2018Aspirant
OK, I reset the AP and the admin password and everything is working as it should.
- JohnC_VDec 13, 2018NETGEAR Employee Retired
Yes, you may change the default password for security. That's great! Please let us know if you need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
