RPL86812's avatar
RPL86812
Default password does NOT work after firmware upgrade
I'm preparing to deploy (6) WAC510 AP units. I'm testing one unit standalone before deploying the other 5. I upgraded the firmware to 5.x latest and went through the day zero setup. After saving and ...
  • JohnC_V's avatar
    JohnC_V
    Dec 12, 2018
    Hi RPL86812,
    Welcome to our community! :)
    I suggest you to reset it to factory default and try to login again using the default password. Is this connected to a wireless controller before?
ProSupport for Business
