jnojr
Nov 24, 2016Guide
Difference(s) between WAC104 and WAC120?
Besides internal / external antenna and $30...
- Nov 27, 2016
Hi jnojr,
Differences between the WAC120 and WAC104:
a. The WAC120 has 2dBi internal antenna while the WAC104 has 3dBi external antenna.
b. The WAC120 has one LAN port while the WAC104 has four LAN ports.
c. The WAC120 supports Band Steering to 5GHz while WAC104 does not.
d. The WAC120 supports VLAN while the WAC104 does not.
e. The WAC120 has QoS Settings while the WAC104 does not.
f. The WAC120 has a total throughput of 1.3 Gbps while the WAC104 has a total throughput of 1.2Gbps.
g. You can enable a syslog server on the WAC120 and this is not supported on the WAC104.
DaneA
NETGEAR Community Team
jnojr
Nov 25, 2016Guide
I already knew that ;-) How does it differ from the WAC120?
DaneA
Nov 27, 2016NETGEAR Employee Retired
Hi jnojr,
DaneA
