bbriner
May 23, 2018Aspirant
Does the WAC505 support 802.11d outside of USA?
Does the WAC505 support 802.11d (country information in the beacon) for units sold outside of the USA?
DaneA
May 23, 2018NETGEAR Employee Retired
Hi bbriner,
Welcome to the community! :)
Kindly read pages 98-99 of the WAC505 user manual here about Change the Country or Region of Operation.
DaneA
NETGEAR Community Team
bbriner
May 24, 2018Aspirant
Thank you for the answer but the manual does not mention if the WR505 broadcasts the country information in the beacon (802.11d).
The issue is that my MacBook Pro finds a wifi in the neighborhood with "China" and adjusts itself to the chinese channels. The only way I found to overcome the problem is to put my R7000 running Tomato to broadcast my correct region. As the R7000 is stronger than my the one broadcasting "China" my MacBook Pro adjusts itself correctly.
Can you please clarify if the WR505 broadcasts or has the option to broadcast the country information ?
- RaghuHRMay 24, 2018NETGEAR Expert
Hi bbriner,
Few questions to understand your issue.
1. Are you seeing becons of WAC505 wrongly sending country code?
2. WAC505 is your AP or neighbour's AP which you do not have access?
3. What is your region? China?
Thanks,
Raghu
- bbrinerMay 24, 2018Aspirant
Hi RaghuHR
1) I don't know if the beacons I see come from a WAC505.
2) I don't have a WAC505. I am currently looking for an AP only to replace my 02 R7000 I currently run as AP in combination with my pfSense.
3) I am in Europe.
To clarify, the bogus AP broadcasting the wrong region "China" is not mine, it comes from the neighborhood and it is pretty strong, I would not be chocked if it is coming from an external directional antenna somehow, even its MAC Address was changed (its vendor is Rolls Royce :smileysurprised:).
If I set my R7000 to not broadcast the country using 802.11d, my MacBook Pro listens to this bogus beacon and adjusts itself to China and I then loose 5Ghz connectivity with my R7000's.
If I set my R7000 to broadcast the country using 802.11d, my R7000 are the strongest signals, so my MacBook Pro picks up the correct information and everything goes as it should.
So before I purchase a WAC505 I need to know 802.11d is broadcasted by default or it can be switched on.
