deviat
Aug 12, 2021Aspirant
Dynamic VLAN on wax
Just picked up a WAX620, spun up Insight, and am pretty stuck on how to configure Dynamic VLANs, or add the additional tagged vlans to the single port. None of the documented help links in Insig...
hnagaraju
Aug 13, 2021NETGEAR Employee Retired
Dynamic VLAN is per SSID configuration.
If you have Insight management enabled. you can enable Dynamic VLAN at the SSID configuration.
Step 1) Go to location configuration and set up the RADIUS server
Step 2) Go to wireless settings and enable Dynamic VLAN.
To make it actually work,
Please make sure the ethernet port where the AP is connected is a TRUNK and allows all VLAN on which the client joins.
deviat
Aug 13, 2021Aspirant
That it is. Is there a specific list or expected attributes the WAX620 is expecting in the access-accept?
