SamBrown
Oct 29, 2019Aspirant
Equipment recommendation wireless router for an auto parts store.
Hello. I'm looking for product recommendation for a wireless router for an auto parts store. The wireless setup will provide the DHCP for the whole shop and wifi to a couple of devices. There will be...
- Nov 05, 2019
Thanks for the insight nmhTester! This answered my question perfectly.
nmhTester
Oct 30, 2019NETGEAR Employee Retired
We have some excellent choices.
OrbiPro (SRK60) : It is system in a box. Router+Switch+Access point all together. easy to setup and get going. It is nicly put other set of features for Prosumers, SOHO offices, SMB that needs simple network. But OrbiPro does not do things like VLAN segeration
you can go for discreat boxes that have all the bells and whistles like VLANs based segmentations, Instant VPN, amazing guest SSID with splash pages (Insight Instant Captive portal).
from hardware wise you will need :
Router===PoESwitch===Access Point.
Example :
BR500==GC510PP==WAC540
Many switch choices different port counts and price-points:
Pick a switch that has right port count you need.
https://www.netgear.com/business/products/switches/smart/smart-pro-cloud.aspx
Access points choices:
WAC510 and WAC540.
- SamBrownNov 05, 2019Aspirant
