jimothy's avatar
jimothy
Extending WiFi to Construction Site
Extending Internet out to Construction Jobsite.   For our jobsite we had ordered security cameras for the jobsite.  The furthest camera is about 250' away from the WiFi router.  My co-worker had or...
  • plemans's avatar
    Mar 09, 2020
    So here's the question. How is it setup?
    are you going
    Linksys------->RBS50Y------>RBS50Y
    or
    RBS50Y<------Linksys------>RBS50Y
    The RBS50Y's will daisy chain fine when running off an orbi router. In extender mode, they function similar to how a standard extender functions. 250ft is also quite a bit of area to cover. Especially if there's obstructions in the way. In my experience, construction equipment tends to block signals very well.
    The other issue is you don't want the extenders at the furthest reaches of the wifi. you want it at the mid-point or its not getting a good enough signal to re-broadcast.
    Another consideration is are you using the extenders in mesh mode (single ssid)? If so, make one of the extenders to have a unique ssid. If they're running in extender mode, they can have issues if they're connecting to each other and not back to the router. When they're running off an orbi router, its not something you need to worry about.
ProSupport for Business
