Finn_Arne's avatar
Finn_Arne
WiFi Range extender WN3000RP V3
I have used this model for several years, but have now got another router. How do I change the password and are there other data I must changes in order to make it work with the new router?
  • Factory reset the extender  and set it up using the installation assistant.
    To factory reset, push and hold the reset button for 7-15 seconds while powered on.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
    I'd probably look at upgrading it though. Its an old/slow extender. Unless you're just using it for IoT devices, its going to be super slow.
  • plemans's avatar
    • Finn_Arne's avatar
      Finn_Arne
      Thank you Plemans
      I will fix it  :-). I use it just for reaching out to the garage and the battey charger for my car, so I think it is fine
