Malek83
Oct 19, 2022Aspirant
Getting almost half of the actual upload speed while using WAX206 (WIFI6)
Hello everyone, I need help to understand why my AP WAX206 is caping my upload speed to half of the actual speed when connecting using Wifi6 (ax), at the same time if I connect a laptop to the sa...
schumaku
Oct 19, 2022Guru - Experienced User
What comes into my mind reflecting the tech specs of the two WAX206 Wi-Fi radios
- Up to 800 Mbps (11ng, HT40, 256-QAM): Performance mode. This mode
allows 802.11n, 802.11g, and 802.11b devices to join the network and allows
802.11ng devices to function at their maximum speed. This mode is the default
mode.
This mode supports a 40 MHz–wide channel and 256 QAM.
• 5 GHz mode: Select one of the following WiFi throughput modes for the 5 GHz
radio:
- Upto 2400 Mbps (80 MHz)(11ax, HT80, 1024-QAM): Performance mode.
This mode allows 802.11ax, 802.11ac, 802.11n, and 802.11a devices to join
the network and allows 802.11ax and 802.11ac devices to function at up to
2400 Mbps. This mode is the default mode.
This mode supports a 80 MHz–wide channel and 1024 QAM.
One possible reason why the 2x2 Wi-Fi clients on the mobile devices tested are pure 2x2 devices, while the WAX206 does employ 4x4. This does divide the possible throughput in two, resp. leave a second half of the available capacity fir a second session.
Nothing wrong with the on-board speed test of the WAX206 - this does not make use of the wireless path, it's direct wired LAN.
Malek83
Ok but why this issue only affects upload not both download and upload. And yes the speedtest on the AP itself is going via wire, I added it for more context that's all. The idea here is that if the WAX206 has 4x4 and clients have 2x2 then I believe this should affect throughput whatever the direction is, correct? Why am I getting full speed on download?
- Malek83Oct 29, 2022AspirantHello,
Any help would be appreciated. I still have the same issue and I don't have any idea how to fix it, I have tried everything already
