TheNetWorks
Jul 13, 2022Aspirant
Guest WiFi Captive Portal unusable
I have installed the WAX610 Access Point at a number of customer sites. For well over a year it has been a "Known Issue" that the captive portal fails to display a pop-up asking the user to acknowledge the terms. Yes there is an alleged work around for it. But I personally have seen this workaround take MINUTES on a very lightly loaded system. This is turning into a support nightmare for my business clients who MUST have captive portal enabled. Does anyone have an honest workaround which works immediately. The supposed workaround is lame. Can't this just be fixed.
I have personally tried this on the last 4 firmware releases with no improvement. This is frustrating as the customers "first impression" is a very bad one.
- RaghuHRNETGEAR Expert
Just want to be clear. What is the model of the wireless client? Is it Android , iOS or Windows lap? Showing pop-up is a wireless client behaviour.
- TheNetWorksAspirant
Oops - should have said. This problem has occurred on a few Android devices that I know of:
Galaxy Note 10 - Running Android 12
Galaxy Tab A7 - Running Android 11
other devices as well. I'm not saying it "works on Windows" - just that it hasn't been tried.
Any insights appreciated!!
