BIG9MM
Jan 15, 2025Apprentice
HELP! WAX630 QoS Settings is greyed out.
Firmware V10.8.11.4. I don't know if it's the firmware or if I'm doing something incorrect but it's not accessible as it doesn't give me the option to disable "WMM Powersave" in the WAX630 web interf...
schumaku
Jan 17, 2025Guru - Experienced User
Clicked this message away?
What issue you intend mitigating from by disabling WMM Power Save?
WMM Power Save deploys mechanisms from 802.11e and legacy 802.11,to save power (for battery powered equipment) and fine-tune power consumption.
- BIG9MMJan 17, 2025Apprentice
The smart Amazon basic light bulbs are disconnecting. Previously I had the option to disable WMM Power Save which caused the light bulbs not to disconnect. The smart Amazon basic light bulbs all do not disconnect but some randomly disconnect because of the WMM Power Save.
