BIG9MM
Jan 15, 2025Apprentice
HELP! WAX630 QoS Settings is greyed out.
Firmware V10.8.11.4. I don't know if it's the firmware or if I'm doing something incorrect but it's not accessible as it doesn't give me the option to disable "WMM Powersave" in the WAX630 web interf...
schumaku
Jan 19, 2025Guru - Experienced User
Pramendra and hnagaraju please, I neither don't know how to adjust the WMM controls in insight, nor do I have an idea why WMM controls are disarmed on the local Web UI (assuming the device is not in insight mode).
- PramendraJan 19, 2025NETGEAR Expert
Acknowledged. Thanks for bringing this to our attention. Allow me some time to check and come back to you on this.
Thanks!
Pramendra Singh
NETGEAR NFB Wireless Team
- BIG9MMJan 21, 2025Apprentice
I opened up previously a support ticket to these issues as well.
- ErwinLJan 23, 2025NETGEAR Moderator
Hello BIG9MM
And welcome to the NETGEAR Community! 🙂
It's good that you have openned a ticket about your issue, so that engineering can take a look at it if needed to be escalated. Have you done a factory reset on the device yet?
Have a lovely day,
Erwin
Netgear Team
