BIG9MM
Jan 15, 2025Apprentice
HELP! WAX630 QoS Settings is greyed out.
Firmware V10.8.11.4. I don't know if it's the firmware or if I'm doing something incorrect but it's not accessible as it doesn't give me the option to disable "WMM Powersave" in the WAX630 web interf...
Pramendra
Jan 19, 2025NETGEAR Expert
Acknowledged. Thanks for bringing this to our attention. Allow me some time to check and come back to you on this.
Thanks!
Pramendra Singh
NETGEAR NFB Wireless Team
BIG9MM
Jan 21, 2025Apprentice
I opened up previously a support ticket to these issues as well.
- ErwinLJan 23, 2025NETGEAR Moderator
Hello BIG9MM
And welcome to the NETGEAR Community! 🙂
It's good that you have openned a ticket about your issue, so that engineering can take a look at it if needed to be escalated. Have you done a factory reset on the device yet?
Have a lovely day,
Erwin
Netgear Team- BIG9MMJan 23, 2025Apprentice
The technical support team over the phone asked the same question you did.
I have a question for you. Have you done a factory reset on your work WAX630 and logged in to see if your functionality is active with the same software I provided above?
Do you guys have access to the same equipment as the WAX630?
I just got a update,
"Hi Robert,
This is Renna and I will be working with you on this case.
I understand that you are looking to disable the WMM Powersave on the WAX630 but the option is greyed out. I have seen the same issue using a lab unit and I have raised this to engineering. I will update you as soon as I hear from them.
Sincerely,
Renna"- ErwinLJan 28, 2025NETGEAR Moderator
Hello BIG9MM
Unfortunately, we do not have the same level of access. However, resetting to factory defaults is a basic troubleshooting step that is often overlooked. If you wish, you may provide an update on your case with our support team?Have a lovely day,
Erwin
Netgear Team
