jfarms
Nov 04, 2023Aspirant
How do I block hostnames? WAX202
Firmware Version V1.0.5.1 I'm trying to block a series of servers at the router level. I have a list of hostnames but I can't figure out if the router has the option to block them? I go to bloc...
schumaku
Nov 04, 2023Guru - Experienced User
Describe your idea a little bit better please.
In general, firewalls can block IP addresses, but not hostnames or FQDNs.
- jfarmsNov 04, 2023Aspirant
so for example one server I want to stop network traffic from pinging has a hostname like fus01.xxx.update.xxxxxxxxx.net - and it doesn't fit in the character limit of the block services page service type field. I have like a bunch of similar addresses I want to block network traffic to.
- schumakuNov 05, 2023Guru - Experienced User
This would be a DNS query done from your LAN (to get the IP address[es]) resolving to one IP or a list of IP addresses. Not much you could to on the average home or SMB router alone.
Where a dedicated local DNS server is available, you can blacklist the host names in question and return a non-existing LAN IP address and device on your network Deploying foe example a Pi-hole as your network DNS server does allow this for example.
