Tom2112
Jan 15, 2025Aspirant
How to disable WPA3 and enable WPA2 only on WAX630E access point?
I have a Netgear WAX630E access point running firmware v10.8.11.4 that I do not have connected to cloud management. The local management interface only has four options for wireless authentication: n...
- Jan 15, 2025
Create the SSID for only 2.4Ghz and 5Ghz Radios.
Only WPA3 is allowed on 6Ghz as per Wi-Fi standards.
If 2.4Ghz/5Ghz/6Ghz is enabled one the SSID, then WPA2/WPA3 is the minimum that is allowed
One common way to achieve this is to create two SSIDs linked to the same wired network.
One WPA3_only SSID is for newer Wi-Fi clients, and another WAP2_only SSID is for legacy Wi-Fi clients.
hnagaraju
Jan 15, 2025NETGEAR Employee Retired
- Tom2112Jan 15, 2025Aspirant
Thank you, hnagaraju!
That worked perfectly! I should have realized the 6 GHz part of it was messing me up. As soon as I disabled 6 GHz (which I wasn't using anyway), I could select WPA2 personal only.
