Giaquo
Jul 05, 2021Tutor
How to manage more than one access point (WAX620 - WAX630)
Hi everyone,
I'm interested to buy some APs, mixed among WAX620 and WAX630. These models have "instant mesh" feature, but I don't understand if insight subscription is required.
Can I join more than one APs without insight, only with local web interface?
- GiaquoTutor
I've found the answer in the WAX630 manual.
https://www.downloads.netgear.com/files/GDC/WAX630/WAX630_UM_EN.pdf
Now I'm wondering why on the consumer market mesh feature is free, while buying an enterprise access point (that costs much more, and in this case it isn't even router) I have to pay...
I have an old router (not Netgear this) I've payed literally a quarter of a WAX630, and I can manage the mesh network from local web-GUI for free.- schumakuGuru - Experienced User
Complete confusion by marketing terms here.
The Instant Mesh term applies only to the ability for defining one (or multiple) wired WAX6xx as root APs where one or multiple WAX6xx can be "connected" wireless making a wireless backhaul for each. What makes up a basic consumer Mesh (802.11k and 802.11v) can be configured (one by one) on each WAC or WAX. Or can you buy wireless routers with 802.11ax and three radios for just a few Dollars somewhere?
The Netgear WAC5xx and WAX6xx are definitively inexpensive business access points when I'm comparing with vendors even requiring mandatory support contracts for firmware updates (even for security), requiring per-device license fees (lack of local management options typically). Consumer Mesh is barely supporting a single VLAN, allows local management only (free single point of failure), does not include switch VLAN management, and much more. Last but not least, most consumer Mesh does not support PoE, does not support MultiGig Ethernet - figure.
With the Insight subscription, you pay for the cloud management, the ability of using 802.11r, full seamless roaming 802.11k/11r/11v) even for clients requiring authentication allowing dynamic VLAN assignment, and much more. Still incredibly inexpensive with some 10 USD per managed device (like WAX or switch) and starting from the second year (1st year is free currently with most new devices).
- GiaquoTutor
First of all, I wouldn't say that a consumer router is better than these APs, but just underline the mesh feature is free in consumer router and I thaught it isn't for these APs...
So, I think you've reason, confused by marketing terms. What is the "instant mesh" technology? From your reply, I've understood is the 802.11r protocol (BSS) added in order to obtain a better "seamless roaming". Then, always from your reply, I suppose that, without insight subscription, I can setup these APs with protocols 802.11k (RRM) and 802.11v, but I have to setup each AP. Let me know if is correct.
At the end, I'd like to explain what I'm looking for in my next APs. I DON'T need the cloud management, and possibly neither a controller (in 2021 the enterprise APs can do what I need without a controller). If I can setup once for all APs is better, obviously, but I need 3-4 APs, so I can setup each one if needed. These APs must be wifi 6 and PoE, with at least 8 spacial streams and 2.5Gbps ethernet port. As multi-APs configuration, it's necessary seamless roaming.
Pay these devices isn't a problem, but for me if I buy a product I have to be able to use all its potential. I don't want to pay forever, even if little, to be able to use MY device. And now I'm wondering if Netgear has a device for me.
Anyway, thanks for your answer and for the availability
- eugene_dAspirant
Hi,
i m in the same situation. I have wired 10Gb route and I need couple of AP to create wi-fi using 802.11k over wiring. And ofcourse If it would be triband 4x4 160Mhz
did u find any interesting model?
Thanks in advance
What is the "of course" coming from - reading to much consumer wireless router marketing or still dreaming of many Gigabits over the air for one computer?
On one hand you unlikely have many (or any) 802.1ax clients to gain any performance advantage.
On the other hand do you have a need to cover that many (ideally ax capable) clients that you need to have these almost 2000 carriers on air?
Last, with spanning 160 MHz (resp 80+80 MHz bandwidth) on the limited amount of channels, you kill the ability to have multiple APs in the area or partially covering the same area. Reality today is that it's not even possible to use the 80 MHz bandwidth in partially overlapping WiFi environments. And I have not even talked about legacy APs (11n/11ax) on air at the same time.
There are reasons why there are not many such devices available in the market.
- GiaquoTutor
Now I'm trying WAX630, I received it yesterday. I've looked for APs from other brand, and I've found a very expensive AP that I would buy (wifi ax, tri-band, embedded wireless controller, external antennas)... But it's unavailable at all, especially in my country.
I'm using the AP without Insight and it seems very interesting. For now, I can test it with a WAX218 AP, with same SSID, and with my wifi ax devices it seems to work fine.
I'll testing it for a month, and if it's good for me I'll buy another one (or two). I'll tell you my opinion at the end of summer.- eugene_dAspirantschumaku, thanks for explanation .
For me it is still out of understanding, why so expensive devices like rax200/raxe500 which can work in AP mode they dont have support for 802.11k/r/v.
Giaquo, What devices did you find?
- AmeliaBelliAspirant
I have read the related info about netgear expan their access point range. Netgear has unveiled the latest addition to its range of WiFi 6 access point devices, the AX6000 Tri-band Multi-gig Access Point (WAX630).
The WAX630 is the fourth part in Netgear's Insight Managed WiFi 6 arrangement of gadgets, which as per the organization is planned explicitly to oblige the requirements of little and medium organizations.
"Regardless of whether it be better in general throughput or quicker speeds for independently associated gadgets, SMBs are continually requesting more from their WiFi organization. The WAX630 conveys industry driving organization execution dependent on its exceptional WiFi 6 12-stream tri-band engineering," said Doug Cheung, Senior Product Line Manager of SMB Wireless at Netgear.
