ntgr_PD
Mar 14, 2023Tutor
How to mount your WAX630, WAX630E, WAX625, & WAX615 to Siemon Max Wifi Faceplate & Single Gang Box
How to mount your WAX630, WAX630E, WAX625, & WAX615 to Siemons' Max Wifi Faceplate & Single Gang Box in the Wall or Ceiling.
Items Required:
- Single Gang Device Box
- Max Wifi Faceplate (PN MX-WB1-02-02) Siemon (screws included)
- Z-Max Cat 6A UTP Outlet Siemon
- SkinnyPatch Cat6A Modular Cords Siemon
- 2X 6-32 x 0.5" Machine screws
- #25 Drill Bit 0.1495"/3.8mm
- WAX630/630E Mounting Plate or WAX625/615 Mounting Plate
Steps:
- Drill one #25 hole spaced on center 3 9/32"/83.3mm from the smaller key slot hole located on center.
- Mount the Max Wifi Faceplate to the Single Gang Box with the two screws provided.
- Mount the AP mounting plate to the faceplate with the 6-32 screws. Note: Orientation for wall mounting. Since the RJ45 port on the AP is always facing up, I mounted the outlets facing up.
- Rotate the Access Point onto the mount until it locks.
- Plug in the patch cord to the Device.
##mounting #accesspoints #singlegang
Cloud Managed WiFi (WAX630) Cloud Managed WiFi 6E Access Point (WAX630EP) Cloud Managed WiFi 6 (WAX615) #wax625
1 Reply
- ntgr_PDTutor
