Howkoss
Jul 24, 2018Tutor
How to remove connected wireless user
How do I remove a wireless user from the access point? I am using 3 WAC505 AC's with the Netgear Insight portal.
- Jul 25, 2018
Thank you. Thak worked.
Retired_Member
Jul 25, 2018Hi Howkoss,
Welcome to the community!
We do have support for MAC ACL in Insight. You can apply it to either Allow certain MAC address and block all others, or vice versa Deny only certain MAC address and allow all others. Please find more information about the configuration steps in the Insight mobile app & Insight cloud portal - How do I set up a WiFi MAC access control list in Insight
Hope this helps
Regards
DavidGo
- schumakuJul 25, 2018Guru - Experienced UserThe usability for this is hmmmm far from user friendly. There should be a way to directly add a device to the denied MAC ACL from the connected clients list.
- Retired_MemberJul 25, 2018
Hi schumaku,
It should be possible, when editing the MAC ACL settings, change the Policy to Deny > then click Add Devices in Denied Devices section. Next screen should show All clients currently connected to the network. Select the desired device and click Deny.
If this doesn't work for you let me know, i'll need to go test it again.....
Thanks
DavidGo
- HowkossJul 25, 2018Tutor
