Howkoss
Jul 24, 2018Tutor
How to remove connected wireless user
How do I remove a wireless user from the access point? I am using 3 WAC505 AC's with the Netgear Insight portal.
- Jul 25, 2018
Thank you. Thak worked.
Retired_Member
Jul 25, 2018Hi schumaku,
It should be possible, when editing the MAC ACL settings, change the Policy to Deny > then click Add Devices in Denied Devices section. Next screen should show All clients currently connected to the network. Select the desired device and click Deny.
If this doesn't work for you let me know, i'll need to go test it again.....
Thanks
DavidGo
Howkoss
Jul 25, 2018Tutor
