GH199
Mar 08, 2021Aspirant
How to switch of the WLAN
Hello Community, can anyone tell me how to switch off the WLAN of my router ? (FVS318N) I logged into the router and did search for it in the menue, but I can´t find it. Thank´s BR
- Mar 12, 2021
Many Thanks schumaku !
In the meantime I've found the solution. You have to do the following steps:
Network Configuration >> Wireless Settings >> mark the Wireless Profile >> click on >> DISABLE
schumaku
Mar 11, 2021Guru - Experienced User
No idea. If you can't disable it, you might look for the ability to disable the beacon (hiding the SSID) and put up a random SSID and password so it does not interfere much with your whatever other wireless.
- GH199Mar 12, 2021Aspirant
