Jeffgear's avatar
Jeffgear
Virtuoso
Oct 07, 2024
guest WLAN isolation
Hi all
Although I use my Guest WLAN for visitors to access the internet, as intended by his feature, I'd like to also use this WLAN for a development Raspberry Pi project I'm working on without creating a vulnerability surface for my primary internal network. However I need to be able to connect from my laptop on the primary WLAN to the Pi on Guest.
The Guest network is 192.168.2.0/24 and the primary one is 192.168.1.0/24.
Is there any configuration settings (e.g. forwarding, static routing) that allows me to:
Ping, SSH and establish a web session from the primary network to a device on Guest?
Assign a DHCP reservation to a device on Guest?
Thanks
  • Guest Networks are isolated from the main WLAN for security reasons. Used to have the ability long ago to give access but NG took that away for security reasons.
    I don't believe you can set a IP address reservation on the main side since the GN is a seperate network and the lease times are short for the intended design of short transient connections while on the GN.
1 Reply
  • FURRYe38's avatar
