CurtisV
Feb 13, 2023Aspirant
IPv6 in AP mode on wax206
Does IPv6 at least work in AP mode (which should just be bridging) on the WAX206. I was intending to use something else as a router and use this as an AP but needed it as a router temporarily while ...
Feb 13, 2023Guru - Experienced User
WiFi devices in AP mode are mostly pass thru for all data traffic so I would presume that while in AP mode, IPv6 would be passing thru. No need for any active IPv6 handling.
Check the support site for what is supported on this model while in AP mode.
