martinav
Jan 17, 2018Guide
Location Map for WAC730 Deployment
I have 5 WAC730 APs. I was looking for some general reccomendations for locating the APs to make a mesh with our WC7500 controller. I have seen similar maps for other brands. How far apart t...
- Jan 19, 2018
Hi martinav,
It will still depend on how you wanted the wireless range it can coverage.
You may also check the manual for WiFi Equipment Placement and Range Guidelines(page 13).
JohnC_V
Jan 19, 2018NETGEAR Employee Retired
Hi martinav,
