bhata
Jul 13, 2016Tutor
MAC Address Restriction and Ensemble Management
I'm looking for a new set of AP's and was reading up on the WAC720 and WAC730. With regards to the MAC Authentication feature, is there a limit on the number of MAC addresses that can be added? ...
- Jul 26, 2016
I have a pair of WAC720s in Ensemble (Firmware 3.5.12.0) and I just checked out the settings for the MAC Authentication. In my testing I found that the MAC Authentication list is shared between Ensemble members. As far as the number of MAC Addresses that you can add I'm not sure but there is a feature to import from a file so I think that you can have a large list. Otherwise you can setup the MAC Authentication to work with a RADIUS server. It should be noted that MAC Authentications are per band(2,4GHz and 5GHz) and not per SSID.
MAC Authentication can be found via the web interface at Configuration>Security>Advanced>MAC Authentication
JohnRo
Jul 18, 2016NETGEAR Employee Retired
Hello bhata,
Welcome to the community!
I have not seen any documentation about the limit on the MAC authentication. I believe the limit will be the same as the total number of users the AP can support. I am not sure yet but definitely, can be inquired to our engineering team. For your second question regarding ensemble, the answer is yes. For now, it can only support the same model per cluster.
Thanks,
