louismccut's avatar
louismccut
Mesh network WAX625 AP and AX6000 Extenders
I recently purchased a WAX625 to set up a VLAN.  My current mesh uses an AX6000 WAP with AX6000 and AX1600 extenders.
Is it possible to use the WAX625 as the access point with the AX6000 and AX1600 as extenders?
  • plemans's avatar
    AX6000 and AX1600 aren't models. They're speeds.
    What actual models do you have?
  • AX5400 (WAX625) new WAP added to network to set up VLAN
    AX6000 (EAX80) currently used as WAP additional AX6000 used as extender
    AX1600 (EAX12) additional extender to AX6000
    • plemans's avatar
      Mixing business class and consumer class isn't really recommended.
      Its also not recommneded to use more than 1 extender. when you're needing more than 1, its recommended to move over to a mesh system (not mesh extender). That way something is controlling the system (router/insight/etc). Or you'll get extenders connecting to each other and not to the primary device or in the proper order because nothing is controlling the system.
      • louismccut's avatar
        louismccut
        I figured it would have issues but was hoping to avoid replacement of existing hardware but that may be the best option.
  • RennaD's avatar
    RennaD
    NETGEAR Moderator
    Hi louismccut,
    We’d greatly appreciate hearing your feedback letting us know if the information provided has helped resolve your concern or if you need further assistance.
    If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    Have a lovely day,
    RennaD
    Netgear Team
ProSupport for Business
