SIFORCE
Mar 22, 2021Aspirant
Multiple SSID on WAC124 not connecting
We have a WAC124 that we have been using for a few months. It was on AP mode with 1 SSID that works fine. I tried adding the 2nd and 3rd avilable SSID today and clicked apply, but devices cannot conn...
schumaku
Mar 23, 2021Guru - Experienced User
The security options are configured according your needs and expectations for the two new wireless networks?
- SIFORCEMar 23, 2021Aspirant
I guess you can say they are, but they just dont work. I am trying to figure out how to make them work before adjusting any changes.
- schumakuMar 23, 2021Guru - Experienced User
There should be nothing that stops you from doing it as long as you don't touch the primary wireless SSID, isn't it?
What is stopping me is that no devices can connect to 2 WIFI SSIDs that are broadcasting, even though the 1st on the same AP works fine.
