SIFORCE
Mar 22, 2021Aspirant
Multiple SSID on WAC124 not connecting
We have a WAC124 that we have been using for a few months. It was on AP mode with 1 SSID that works fine. I tried adding the 2nd and 3rd avilable SSID today and clicked apply, but devices cannot conn...
SIFORCE
Mar 23, 2021Aspirant
I guess you can say they are, but they just dont work. I am trying to figure out how to make them work before adjusting any changes.
schumaku
Mar 23, 2021Guru - Experienced User
There should be nothing that stops you from doing it as long as you don't touch the primary wireless SSID, isn't it?
- SIFORCEMar 23, 2021Aspirant
What is stopping me is that no devices can connect to 2 WIFI SSIDs that are broadcasting, even though the 1st on the same AP works fine.
- schumakuMar 24, 2021Guru - Experienced User
The reason why wireless clients "don't connect" is a variable target.
It can be caused the security configured on the wireless client does not matching the SSID config, or security methods and/or authentication schemes not being available, or - and here the wireless connection can be established so there is a workable L2 connection - and the clients don't have or don't get a valid IP config applied, probably due to the newer fancy "private" MAC by network connection and you might allow only white listed devices. So you see - there is much more than just an SSID visible on air.
....back to the question I had asked with my first reply.
- SIFORCEMar 24, 2021Aspirant
Is my issue that there is custom options specific to an SSID that I am not configuring? I did not do any fancy VLANs like some cisco AP support postings mention, or any whitelist preferences. I was under the impression the 2nd and 3rd SSID would be just as open to anyone with the the password
