64dude
Dec 13, 2024Guide
Multiple WAX206 unstable after firmware update v1.0.5.3
After updating to this version on two different WAX206 running in AP mode, the following occurs so far randomly: - 5GHz radio stops altogether - happens simultaneously on all devices. All were runni...
baumkp
Dec 29, 2024Aspirant
I am having similar problems. I have 2 x WAX206 in AP mode to give good coverage throughout my house. Since the firmware update to v1.0.5.3 one unit has failed multiple times, particularly on the 5GHz Wifi, it seems to be every 1 or 2 days. I notice as the wifi signal strength is very poor in part of house when only one unit is operational. A simple power reset resolves the issue. Before the firmware update both units operated reliably.
- hnagarajuDec 30, 2024NETGEAR Employee Retired
We are looking into this.
- NiveditaJan 05, 2025NETGEAR Expert
Hi,
Could you please share download logs, for further debug.
Thanks,
Nivedita
- baumkpJan 06, 2025Aspirant
I just checked the one unit has been running reliably since Dec 30. The other unit had stopped functioning and needed reset. The logs do not show any "interesting" debug information. e.g. from just reset unit:
[admin login] from source 192.168.1.71, Monday, January 06, 2025 16:39:44
[Internet connected] IP address: 192.168.1.90, Monday, January 06, 2025 16:38:46
[Time synchronized with NTP server] Monday, January 06, 2025 16:38:34
[DHCPC] bound IP address: 192.168.1.90, Thursday, January 02, 2025 10:51:50
[DHCPC] deconfig address: Thursday, January 02, 2025 10:51:43
[Initialized, firmware version: V1.0.5.3] Monday, January 06, 2025 16:38:30- NiveditaJan 06, 2025NETGEAR Expert
Thank you for your quick response,
Does the second unit after 'reset' is functioning normal?.
How did you reset the board.
Thanks,
Nivedita
