Cafetom
Dec 01, 2021Star
Need Suggestions on products to purchase
Hello all, I am looking for product suggestions. I am a long time Nighthawk router customer for my home. I am also a high end tech user. I have my own datacenter in my house running vmware hybrid...
hnagaraju
Dec 01, 2021NETGEAR Employee Retired
SXR80 and SXR30 can be your Business router.
If you have lot of traffic, SXR80 will be better suited.
It supports 5 DHCP Pools.
can support up to 512 DHCP address.
Can support reserving IP address for some clients (useful for IOT deployments)
It has upto 4 SSIDs/WLAN (WirelessLAN) that can be mapped to different VLANs.
Depending on walls and how your floor plan is, you may need 3 to 5 SXS80 to blanket your 6000 sqft of building.
One more good thing about SXS80 is the Ethernert ports on them.
So you can wire up some of these IOT devices incase they do not have good Wi-Fi clients built in. These ports can be configured as Trunk or access ports. They can also LAG enabled if you have high end servers that need two ethernet cables for redundency.
