JackalopeWolf
Jan 09, 2023Aspirant
NETGEAR® Insight WiFi 6 AX6000 Tri-Band Multi-Gig Access Point (WAX630) - DHCP Release option?
Hi there, apologies if this is in the wrong section, does anyone know where exactly in the Netgear management section that I can find the DHCP Release time sections so that when wireless devic...
schumaku
Jan 10, 2023Guru - Experienced User
Hm, usually the DHCP server for a network is operated on a different device, unlikely not on a Wireless Access Point like a WAX630. So a little bit unclear what information you are behind here for configuring the lease time.
JackalopeWolf
Jan 10, 2023Aspirant
Hi there,
So with one of the Netgear Wireless Access Points there is a DHCP Lease option where you can set it to release the IP's of connected devices from anywhere to 1 minute to 1 day - as we have a lot of connected Devices throughout the day sometimes it won't release IP's for other to connect, that make sense?
So in short a lot of devices that connect to it still can without waiting on a IP to come available on the connected SSID's.
However I spoke to netgear directly as I was able to get through to them! this doesn't support DHCP IP Client lease option so will have to put it on a scheduled reboot.
