JackalopeWolf
Jan 09, 2023Aspirant
NETGEAR® Insight WiFi 6 AX6000 Tri-Band Multi-Gig Access Point (WAX630) - DHCP Release option?
Hi there, apologies if this is in the wrong section, does anyone know where exactly in the Netgear management section that I can find the DHCP Release time sections so that when wireless devic...
schumaku
Jan 10, 2023Guru - Experienced User
Hm, usually the DHCP server for a network is operated on a different device, unlikely not on a Wireless Access Point like a WAX630. So a little bit unclear what information you are behind here for configuring the lease time.
JackalopeWolf
Jan 10, 2023Aspirant
Do you know if the
Netgear WAC720 ProSAFE Dual Band Wireless AC Access Point has the option to set scheduled reboots? can see it has a schedule for when SSID's can go over during the week and weekends?
