crflores
Jan 26, 2022Aspirant
NetGear AP WAX214 - AX 1800 Cannot Connect Android Device
I'm Receiving the following Error While Trying to Connect to the AP an Android 11 HK1 MAX TV Box (mac address 5c:f8:a1:a1:e9:d7), I was able to connect to a old LinkSys Router without Issues but af...
crflores
Jan 27, 2022Aspirant
The Security is WPA2-Personal
Jan 27, 2022Guru - Experienced User
what channel are you using for 2.4ghz?
Have you tried changing?
What's the android device giving you for an error?
- crfloresJan 27, 2022Aspirant
At this moment is set to All
Yes, I have tried to change it to 1, 6, 11
No only that cannot Find the NetWork.
but as you see on the original message of this tread, on the logs seems at first that is authenticated and then associated, but inmediatly gets disassociated.
- plemansJan 27, 2022Guru - Experienced User
I'm not sure how its associating if the device isn't even finding/seeing the network.
I see you've disabled AX, does it see it if its enabled?
- crfloresJan 28, 2022Aspirant
If I Enable the Only the AX for the 2.4 GHZ band the TVBox will try to connect to the 5 GHZ and also will have the same error
