lucas08
Apr 21, 2023Follower
Netgear R6700AX to Netgear Access Point WAX206
I was trying to read the installation instructions for this set up and I'm a bit lost. The way I had it explained to me is all I had to do was set up the router and plug in a cable from the R6700AX t...
Apr 21, 2023Guru - Experienced User
Here's a video walk through of the wax202. The WAX206 should be pretty much the same for setup.
https://www.youtube.com/watch?v=aElkgZFbEUw
