a1chin
Oct 09, 2023Follower
Netgear WAX202 Router on AP mode showing devices on connected WAN router
I recently purchased a Netgear WAX202 Router to act as an access point for just my PC/Pico 4 VR headset. The issue is I can see all the other devices connected to my BT Smart Hub 2 router. I have t...
FunkySplurge
Oct 09, 2023Aspirant
Many thanks to a1chin for sharing this post from my original post on the NETGEAR subreddit 👍.
This is how far I've got so far, ignore the yellow/red circles this was for another post on Reddit.
I'm confused as to what I should change at this point as I have no idea what IP addresses I should put in.
"setting the DHCP pool to a smaller set of IP addresses" Would it help if I posted the IP addresses of the BT Smart Hub 2?
schumaku
Oct 09, 2023Guru - Experienced User
Would it help to tell you that setting a fixed LAN IP address for your WAX20x does not add any privacy or security? It's still in the very same LAN IP subnet!
