jurek224466
Feb 20, 2022Guide
Netgear wax218- 2.4GHz radio random disabling
I have a problem with the Netgear WAX218 router. After switching the channel width to 20MHz / 40MHz, my radio fades to 2.4GHz. When I have the 40MHz channel set my 2.4GHz radio turns off randomly but...
DaneA
Feb 22, 2022NETGEAR Employee Retired
Was everything working fine before?
Let us try this. Kindly disable 11ax mode then check if the same problem will occur.
DaneA
NETGEAR Community Team
jurek224466
Feb 27, 2022Guide
Hi. I have had such problems for some time. On the 40MHz channel it works fine after turning off the 11ax mode. Now I will test it on the 20MHz / 40MHz setting. I will let you know what and how.
- jurek224466Feb 28, 2022Guide
Niestety w trybie 20MHz / 40MHz radio 2.4GHz nie działa z wyłączonym trybem 802.11ax. Zauważyłem również, że czasami prędkość sieci LAN wynosi 100 Mb / s zamiast 1 Gb. Z reguły jest to 1Gb.
