jurek224466
Feb 20, 2022Guide
Netgear wax218- 2.4GHz radio random disabling
I have a problem with the Netgear WAX218 router. After switching the channel width to 20MHz / 40MHz, my radio fades to 2.4GHz. When I have the 40MHz channel set my 2.4GHz radio turns off randomly but...
DaneA
Mar 07, 2022NETGEAR Employee Retired
Let us try this. Perform a factory reset on your WAX218 then reconfigure the settings from scratch. Observe if the same issue will occur.
DaneA
NETGEAR Community Team
- jurek224466Mar 07, 2022Guide
I have already tried restoring the firmware to the factory settings and it did not work. I was also doing a downgrade and it was useless.
- DaneAMar 15, 2022NETGEAR Employee Retired
This needs further investigation. I suggest you to open a support ticket with NETGEAR Support here at anytime. Kindly state that status of your WAX218 and the troubleshooting steps done to isolate the problem as well as you can include a link to this thread.
DaneA
- blljybobbyw22Jun 12, 2022Aspirant
Has this issue been resolved? I am experiencing the same issues with my WAX218.
