jurek224466
Feb 20, 2022Guide
Netgear wax218- 2.4GHz radio random disabling
I have a problem with the Netgear WAX218 router. After switching the channel width to 20MHz / 40MHz, my radio fades to 2.4GHz. When I have the 40MHz channel set my 2.4GHz radio turns off randomly but...
jurek224466
Jun 21, 2022Guide
I think I found what's causing the problem. Try to set the static channel to 2.4GHz in your copy, for example on channel 6. I checked it on two devices. One is mine and the other is new and the web is visible. Let me know what the situation is like for you.
