Gary7641
Aug 25, 2023Aspirant
Netgear WAX620 country can't change to Asia
Hi All, May I know how to change the device location to Hong Kong, or Asia ? I find say need to update the firmware, but I can't find out any firmware can support change country to Hong Kong or As...
schumaku
Aug 25, 2023Guru - Experienced User
It's not a question of the firmware in place. These AP are location specific products, it's burned in the device during the manufacturing process. Some variants, like the ones offered in the US for the North American / FCC regulatory area (WAX620-100NAS) can't be user-changed. FCC regulation prohibit such a location config change.
Gary7641
Thank you !
Since I can’t add devices, message some the location issues, already fixed. Many thank for you kindly reply let me know more, thanks
- schumakuAug 25, 2023Guru - Experienced User
It's key to order the appropriate device for the installation region, for example
Ordering Information
WAX625-100APS Asia Pacific
WAX625-100CNS Canada
WAX625-100EUS Europe
WAX625-100NAS US
WAX625PA-100NAS US (Power adapter included)- Gary7641Aug 25, 2023AspirantJust wonder if the country can’t change, why use the pull-down menu 🤔. Just the the information will be better 😅
