Gary7641
Aug 25, 2023Aspirant
Netgear WAX620 country can't change to Asia
Hi All, May I know how to change the device location to Hong Kong, or Asia ? I find say need to update the firmware, but I can't find out any firmware can support change country to Hong Kong or As...
Gary7641
Thank you !
Since I can’t add devices, message some the location issues, already fixed. Many thank for you kindly reply let me know more, thanks
schumaku
Aug 25, 2023Guru - Experienced User
It's key to order the appropriate device for the installation region, for example
Ordering Information
WAX625-100APS Asia Pacific
WAX625-100CNS Canada
WAX625-100EUS Europe
WAX625-100NAS US
WAX625PA-100NAS US (Power adapter included)
- Gary7641Aug 25, 2023AspirantJust wonder if the country can’t change, why use the pull-down menu 🤔. Just the the information will be better 😅
