Base209
Jan 15, 2025Aspirant
Netgear WAX625 Slow 300Mbps Max WiFi
Hi. I am having a problem with my Netgear WAX625 Wireless Access Point (WAP) that I have seen reported by users of other Netgear WAPS. I have a 500Mbps FTP connection. However my Netgear WAX625 5Ghz W...
schumaku
Jan 16, 2025Guru - Experienced User
Double check your wireless client is not associating to the 2.4 GHz band SSID.
Ensure you have configured the Channel Width to at least 80 MHz, better 160 MHz. For simplicity, you can also choose Auto where available.
Base209
Jan 17, 2025Aspirant
That solved it, I have adjusted the width and am now getting 500Mbps. Thank you very much.
