Caden_Cotard's avatar
Caden_Cotard
Netgear WAX630E- Beacon Protection Feature
Hi all,
I have been using Netgear Triband access point Model Number - WAX630E. I noticed this while capturing that without enabling the beacon protection some of the beacons are being transmitted with protection. So i wanna know is there's any way to disable the beacon protection feature in netgear access point?
  • schumaku's avatar
    schumaku
    Probably not without disabling WPA3 where the beacon protection by a key was implemented (default on 6 GHz, so there its certainly a no-no). Comes the question why one does want this risky configuration?
    A little bit confused because you asked about "how to enable beacon protection feature in netgear access point (netgear 6e WAX630E)??" on reddit 8-/
    • Caden_Cotard's avatar
      Caden_Cotard
      If there is an option to enable and disable the beacon protection provided in netgear access point, it would be an added advantage for me to check the behaviour. That's the reason i asked about how to enable and disable it.
      Secondly, i didn't enabled it. So i wanna know why the access point transmitting protection beacons (not in a regular interval)
      • schumaku's avatar
        schumaku
        Start with do disabled WPA3 (where it's a default requirement) so use WPA2 only..
        Needless to say WPA3 is the standard for 6 GHz.
ProSupport for Business
