dfunkt
Apr 06, 2023Aspirant
Netgear WAX630E and Netgear MS108EUP multi gig - still slow wifi speeds - help!!
My setup House included Araknis 500 and 200 series AP and switch combo with about 350ish up/down speed Internet: AT&T lightspeed fiber connection at Current Speed (Mbps)Current Duplex 1000...
schumaku
Apr 07, 2023Guru - Experienced User
Your ATT provided Modem/Router does support MultiGig on the blue 5 GbE port, so a full 2.5 GbE is reached from your WAX630E through the MS108EUP.
No odd Mesh configured on these WAX? Usual reasons for non-usual WiFi performance is in the channel layout and availability, not fully open max bandwidth, overlapping wireless equipment (interferences).
dfunkt
Apr 07, 2023Aspirant
Also, as you can see, I am in front of my WAX630E with my iPad Pro getting Speedtest.net results just a couple of minutes ago.
And this is the back of the WAX630E WAP with the cat6 regular cable attached to the 2.5gb POE port which is attached to the MS108EUP 2.5gb POE++ port 1.
