thatguy12
Jan 23, 2023Follower
Orbi SXR30 as gateway with MS510TXUP Switch and WAX630E AP
As the title suggests I'm designing a high end wireless system for a home business application. I was considering using the MS510TXUP as my main switch with TWO WAX630E access points. However, it seems like Netgear doesn't offer a wire-only basic router to incorporate with these components. Ideally I'd like to monitor everything from Netgear Insight app including router status/management.
So I'm wondering if the following will work?
WAN into a single Netgear Orbi SXR30 (with radios turned off)
Ethernet Out of SXR30 into MS510TXUP as internet uplink
WAX630E connected to MS510TXUP over POE++
Will I be able to manage all of these devices under one location in Netgear Insight?
Thanks for the help
1 Reply
The Orbi SXR30 does support four networks, with four VLANs and SSIDs if desired https://kb.netgear.com/000062267/How-do-I-assign-a-VLAN-to-my-SSID-on-my-Orbi-Pro-WiFi-6 With the assistance of Netgear Insight you have everything in a single management environment.
